Water Overlay
What are the Water Overlays
Configuration Wizard
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Hydrological features
Water level area
Attribute | Unit | Description | Default (when attribute is not present) |
WATER_LEVEL | mNAP | The water level for all water terrains in this water level area | n/a |
Sewer area
SEWER_STORAGE | m | The maximum height the water can reach in this sewer. This value, multiplied by the surface area of the sewered constructions the sewer area intersects with, forms the total amount of water this sewer can store. | n/a |
SEWER_PUMP_SPEED | m3/s | The amount of water removed from the sewer by removing it from the hydrological model entirely. | 0 |
Breach
SURFACE_OVERRIDE | mNAP | The new terrain height at the location of the breach. | n/a |
INLET_Q | m3/sec | The maximum amount of water flowing into the model through this breach. A negative value means the breach functions as an outlet, and water is removed from the hydrological model. | 0 |
INLET_CAPACITY | m3 | The maximum amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. | Infinite |
LOWER_THRESHOLD | mNAP | If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
UPPER_THRESHOLD | mNAP | If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Note that a breach shares attribute names with the inlets, and that changing the attribute keys for breaches also affects the keys for inlets.
Inundation
INUNDATION_LEVEL | mNAP | The height of the water. | n/a |
Hydrological constructions
- Line-based constructions
Culvert
Attribute | Unit | Description | Default |
CULVERT_WIDTH | m | The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. | 1 |
CULVERT_HEIGHT | mNAP | The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) | 0 |
CULVERT_N | manning value | The manning value of the culvert's material, which influences the flow speed. | 0,014 |
Weir
WEIR_HEIGHT | mNAP | The height of the weir. | n/a |
WEIR_WIDTH | m | The width of the weir. | 5 |
WEIR_COEFFICIENT | coefficient | The flow coefficient related to the shape of the weir | 1,1 |
Pump
PUMP_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | n/a |
Sewer overflow
SEWER_OVERFLOW | mNAP | The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water level in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out. | n/a |
SEWER_OVERFLOW_SPEED | m3/s | The maximum speed at which water can flow out from the sewer through this overflow. | 10 |
Inlet
INLET_Q | m3/sec | The maximum amount of water flowing into the model through this inlet. A negative value means the construction functions as an outlet, and water is removed from the hydrological model. | n/a |
INLET_CAPACITY | m3 | The maximum amount of water which can flow in or out through this construction. Water flowing back in the other direction replenishes the capacity. | Infinite |
LOWER_THRESHOLD | mNAP | If a lower threshold is set, water will only flow into the model through this inlet until the water level at the point of this inlet is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
UPPER_THRESHOLD | mNAP | If an upper threshold is set, water will only flow out the model through this outlet until the water level at the point of this inlet is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Note that an inlet shares attribute names with the breaches, and that changing the attribute keys for inlets also affects the keys for breaches.
Miscellaneous constructions
Besides the constructions which directly influence the main water flow in the hydrological model, there are some constructions which interact with the model in other ways.
The effects of these constructions can be adjusted by setting the appropriate attributes. In some cases, these are attributes which relate to function values. For these attributes, either can be adjusted to the same effect.
In contrast with hydrological constructions and their properties, all constructions can have any or all of the following miscellaneous effects.
Sewered constructions
Attribute | Unit | Function value | Description |
SEWERED | boolean | Connected to sewer | Whether this construction is connected to the sewer. |
Water storage constructions
WATER_STORAGE | m³/m² | Water storage (m³/m²) | How much water this construction can store. |
Porous constructions
GROUND_INFILTRATION_MD | m/day | Ground infiltration per day (m) | The speed at which water can flow vertically from the surface to the underground unsaturated zone. |
Crops and foliage
ROOT_DEPTH_M | m | Depth of plant roots (m) | The depth of the roots of this construction, relative to the terrain height at the location of this construction. Water can be drawn from the underground and evaporated if the roots can reach it. |
WATER_EVAPORATION_FACTOR | factor | Water evaporation | How fast this construction can evaporate water from the underground. The weather's evaporation speed is multiplied by this factor to determine the rate of evaporation. |
Chemical emitters
CHLORIDE | x/m² | The amount of chloride created per second per m² in this location. | 0 |
NITROGEN | x/m² | The amount of nitrogen created per second per m² in this location. | 0 |
PHOSPHORUS | x/m² | The amount of phosphorus created per second per m² in this location. | 0 |
Water
Attribute | Unit | Terrain type | Description |
WATER | boolean | Surface | Whether the specified terrain is a water terrain. |
Evaporation
ROOT_DEPTH_M | m | Surface | The depth of the roots of this surface terrain, relative to the surface. Water can be drawn from the underground and evaporated if the roots can reach it. |
WATER_EVAPORATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the underground. The weather's evaporation speed is multiplied by this factor to determine the rate of evaporation. |
Infiltration and storage
Result types
Result type | Unit | Display mode | Description |
BASE_TYPES | Nominal value | Start | Categorization of the individual cells based on how they are processed by the water model, displaying which cells are considered to be specific features. 0: Cell on the edge of the project area |
CHLORIDE | x/m² | Last | The amount of chloride present. The value is the sum of the quantities on the surface, and the underground. |
DIRECTION | Degrees | Last | The direction in which water is flowing. |
EVAPORATED | m (mm)¹ | Total | The amount of water that has evaporated. The value is the sum of the quantities evaporated from the surface and the underground. |
GPU OVERVIEW | nominal value | Maximum | Shows which GPU cluster calculated which part of the overlay. |
IMPACTED_BUILDINGS | nominal value | Maximum | Constructions impacted by excess water. Constructions are considered impacted when the construction itself or an adjacent cell contains more water on the surface than configured in IMPACT_FLOOD_TRESHOLD_M. 0: Construction is not impacted |
LAST SPEED | m/s | Last | The speed of water flow in any given location. |
MAX SPEED | m/s | Maximum | The speed of water flow in any given location. |
NITROGEN | x/m² | Last | The amount of nitrogen present. The value is the sum of the quantities on the surface, and the underground. |
PHOSPHORUS | x/m² | Last | The amount of phosphorus present. The value is the sum of the quantities on the surface, and the underground. |
SEWER_LAST_VALUE | m (mm)¹ | Last | The amount of water stored in the sewer. |
SEWER_MAX_VALUE | m (mm)¹ | Maximum | The amount of water stored in the sewer. |
SURFACE_DURATION | s (min)¹ | Total | The amount of time the water depth on the surface exceeds SHOW_DURATION_FLOOD_LEVEL_M. |
SURFACE_FLOW | m³/m² | ||
SURFACE_LAST_VALUE | m (mm)¹ | Last | The amount of water on the surface. |
SURFACE_MAX_VALUE | m (mm)¹ | Maximum | The amount of water on the surface. |
UNDERGROUND_FLOW | m³/m² | ||
UNDERGROUND_LAST_STORAGE | m (mm)¹ | Last | The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep. |
UNDERGROUND_LAST_VALUE | m (mm)¹ | Last | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep. |
UNDERGROUND_MAX_STORAGE | m (mm)¹ | Maximum | The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps. |
UNDERGROUND_MAX_VALUE | m (mm)¹ | Maximum | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps. |
UNDERGROUND WATERTABLE | m + datum | Last | The groundwater level, relative to datum. |
WATER_STRESS | m (mm)¹ | Maximum | The amount of water on the surface, similar to SURFACE_MAX_VALUE. However, for water terrains, the water level must rise by at least ALLOWED_WATER_INCREASE_M. Otherwise, the value in those locations is 0. |
Result child overlays
Currently, it is only possible to add result child overlays via the configuration wizard.
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
Water Level | m + datum | initial water level, relative to datum, for all water cells in a water area |
Outlet | m3/s | water abstraction for all water cells in a water area |
Outlet level | m + datum | initial water level, relative to datum, for all water cells in an outlet area (breach for example) |
Outlet capacity | m3 | maximum amount of water that can be used for the outlet |
Sewer Storage | m | available storage in sewers at the start of simulation in a sewer area |
Sewer Pump Speed | m3/s | sewer water abstraction for all cells in a sewer area |
Breach Floor | mNAP | Modified terrain height, to simulate a breach in a levee. |
Inundation level | mNAP | Initial water height, to simulate water present at the start of the simulation. |
Weir Height | m + datum | weir crest level |
Weir Output | m3/s | The amount of water that flows through a weir/culvert |
Weir Coefficient | linear weir coefficient for accounting discharge & contraction losses | |
Culvert Speed | m3/s | the discharge capacity of a culvert |
Pump Speed | m3/s | the capacity of a pump |
Sewer Overflow Height | m + datum | the height of a crest of a sewer overflow |
Sewer Overflow Speed | m3/s | the discharge capacity of a sewer overflow |
Chloride | x/m2 | Amount* of chloride which is created per second, per m² of construction with this attribute. |
Nitrogen | x/m2 | Amount* of nitrogen which is created per second, per m² of construction with this attribute. |
Phosphorus | x/m2 | Amount* of phosphorus which is created per second, per m² of construction with this attribute. |
Attributes tab
ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type |
AVG_SURFACE_WATER | Description wil be added | |
DESIGN_FLOOD_ELEVATION_M | m | Constructions in the 3D world are assumed to have at most this height compared to the surface of the terrain. Greater values can create a more accurate model but will impact performance. |
GROUND_BOTTOM_DISTANCE_M | m | Assumed distance under the terrain surface where the soil becomes impenetrable for water. The groundwater level cannot go below this depth, relative to the surface. The maximum amount of water that can be stored underground is equal to this attribute multiplied by the local terrain's WATER_STORAGE_PERCENTAGE. |
GROUND_WATER | Description wil be added | |
IMPACT_FLOOD_THRESHOLD_M | m | maximum waterdepth on a cell which touches the building where after the building is assumed impacted, visualized in the IMPACTED_BUILDINGS result type |
MAX_SPEED_MS | Maximum speed at which water is allowed to flow. As the maximum speed is set higher, the time per step of the calculation is reduced, increasing total time for the calculation to complete. | |
MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
SHOW_DURATION_FLOOD_LEVEL_M | m | threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type |
SUPERGRID | This marks an experimental feature which is currently under development and may result in unexpected behavior when activated. | |
SURFACE_WATER_EVAPORATION_FACTOR | Description wil be added | |
TIMEFRAMES | the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number). |
