Water Overlay
What are the Water Overlays
Configuration Wizard
File:Config wizard.JPG
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Hydrological features
Water level area
| WATER_LEVEL | mNAP | The water level for all water terrains in this water level area | n/a |
Sewer area
Breach
| SURFACE_OVERRIDE | mNAP | The new terrain height at the location of the breach. | n/a |
| INLET_CAPACITY | m3 | The maximum amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. | Infinite |
| LOWER_THRESHOLD | mNAP | If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
| UPPER_THRESHOLD | mNAP | If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Note that a breach shares attribute names with the inlets, and that changing the attribute keys for breaches also affects the keys for inlets.
Inundation
| INUNDATION_LEVEL | mNAP | The height of the water. | n/a |
Hydrological constructions
- Line-based constructions
Culvert
| CULVERT_HEIGHT | mNAP | The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) | 0 |
Weir
| WEIR_HEIGHT | mNAP | The height of the weir. | n/a |
Pump
| PUMP_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | n/a |
Sewer overflow
| SEWER_OVERFLOW | mNAP | The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water level in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out. | n/a |
Inlet
| LOWER_THRESHOLD | mNAP | If a lower threshold is set, water will only flow into the model through this inlet until the water level at the point of this inlet is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
| UPPER_THRESHOLD | mNAP | If an upper threshold is set, water will only flow out the model through this outlet until the water level at the point of this inlet is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Note that an inlet shares attribute names with the breaches, and that changing the attribute keys for inlets also affects the keys for breaches.
Miscellaneous constructions
Besides the constructions which directly influence the main water flow in the hydrological model, there are some constructions which interact with the model in other ways.
The effects of these constructions can be adjusted by setting the appropriate attributes. In some cases, these are attributes which relate to function values. For these attributes, either can be adjusted to the same effect.
In contrast with hydrological constructions and their properties, all constructions can have any or all of the following miscellaneous effects.
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Chemical emitters
Water
Evaporation
Infiltration and storage
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
| Result type | Unit | Description |
| BASE_TYPES | nominal value | Division of gridcells in water, land, water level areas, sewer areas that are connected to the sewer, breach areas and hydrological constructions |
| CHLORIDE | x/m² | Description will be added when available |
| DIRECTION | Degrees | The direction of the flooding |
| EVAPORATED | m (mm)¹ | The amount of water that is evaporated |
| GPU OVERVIEW | nominal value | Shows which GPU cluster calculated which part of the overlay |
| IMPACTED_BUILDINGS | nominal value | Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M |
| LAST SPEED | m/s | The speed of the flooding at the last calculated timestep |
| MAX SPEED | m/s | The maximum speed of the flooding of all the calculated timesteps |
| NITROGEN | Description will be added when available | |
| PHOSPHORUS | Description will be added when available | |
| SEWER_LAST_VALUE | m (mm)¹ | The amount of water in the sewer storage at the last calculated timestep |
| SEWER_MAX_VALUE | m (mm)¹ | The maximum amount of water in the sewer storage of all the calculated timesteps |
| SURFACE_DURATION | s (min)¹ | The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M |
| SURFACE_FLOW | m3/m2 | Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2) |
| SURFACE_LAST_VALUE | m (mm)¹ | The water depth at the last calculated timestep |
| SURFACE_MAX_VALUE | m (mm)¹ | The maximum water depth of all the calculated timesteps |
| UNDERGROUND_FLOW | m³/m² | Total infiltration amount from the surface to groundwater |
| UNDERGROUND_LAST_STORAGE | The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep | |
| UNDERGROUND_LAST_VALUE | m (mm)¹ | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep |
| UNDERGROUND_MAX_STORAGE | The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps | |
| UNDERGROUND_MAX_VALUE | m (mm)¹ | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps |
| UNDERGROUND WATERTABLE | mNAP | The groundwater level, relative to NAP, at the last calculated timestep. |
| WATER_STRESS | m (mm)¹ | The maximum water depth of all the calculated timesteps (almost the same as the SURFACE_MAX_VALUE, but if the terrain type is water only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M) |
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
| Breach Floor | mNAP | Modified terrain height, to simulate a breach in a levee. |
| Inundation level | mNAP | Initial water height, to simulate water present at the start of the simulation. |
Attributes tab
| ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type |
| AVG_SURFACE_WATER | Description wil be added | |
| GROUND_WATER | Description wil be added | |
| IMPACT_FLOOD_THRESHOLD_M | m | maximum waterdepth on a cell which touches the building where after the building is assumed impacted, visualized in the IMPACTED_BUILDINGS result type |
| MAX_SPEED_MS | Maximum speed at which water is allowed to flow. As the maximum speed is set higher, the time per step of the calculation is reduced, increasing total time for the calculation to complete. | |
| MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
| SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
| SHOW_DURATION_FLOOD_LEVEL_M | m | threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type |
| SUPERGRID | This marks an experimental feature which is currently under development and may result in unexpected behavior when activated. | |
| SURFACE_WATER_EVAPORATION_FACTOR | Description wil be added | |
| TIMEFRAMES | the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number). |
