Sight Distance Overlay
Revision as of 09:34, 5 November 2018 by Maria@tygron.com (talk | contribs)
What the Distance Sight Overlay is
File:Sight Distance overlay.jpg
This Distance Sight Overlay combines the Distance Zone as defined by constructions with the direct line of sight for these constructions. The distance zone is always a circle situated around the affected construction(s).
The radius of this circle can be adjusted in the function value table.The Distance Sight Overlay becomes available for all stakeholders when added to a project. This overlay can be activated by clicking the corresponding icon on the minimap. When activated the Distance Sight Overlay displays 3 colors, red, yellow and green. Different colors mean different distances of the object with the distance zone to other objects in the 3D World.
Color Red
Nearby = - 217
Color Yellow
Average distance = 0
Color Green
Far away = 127
The distance of the selected object which has a distance zone is displayed
When clicking on a specific location on the map, the hover panel gives additional information of the distance from the clicked location to the object which has a distance zone.
Adding and removing the Distance Sight Overlay
Template:Editor ribbon
How to add the Distance Sight Overlay:
  2. Select 'Overlays' from the ribbon bar
  3. Select the Distance Sight Overlay from the drop down menu
How to remove the Distance Sight Overlay:
  3. Select the Distance Sight Overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
Modifying the Legend of the Distance Sight Overlay
How to Modify the Legend of the Distance Sight Overlay:
  1. Select the Distance Sight Overlay from list of overlays in the right panel
  2. Select the Legend bar in the left panel
  3. Notice the distance values with corresponding colors
  4. Select the "Has Custom Legend" option
  5. Select "Add" at the bottom of the left panel
  6. A new Entry will appear with value 0 Enter a name for the entry
  7. Edit the name, value and color of the new entry
  8. Notice that the entry is automatically sorted
