Distance Overlay
What the Distance Zone Overlay is
The Distance Zone Overlay is an Overlay which can be used for displaying zones around constructions. One use case for this could be a zone around a wind turbine that resembles the noise contour. The distance zone is always a circle situated around the affected construction(s). The radius of this circle can be adjusted in the function value tabel. See below for more information on how to adjust the function value. The overlay can also be modified to count how many zones are overlapping each other. See below for more information on how to enable this "Count Hits instead of Distance" option. An example use case for this overlay can be found on the Usecase Distance Overlay page.
The distance of the selected building from the bus stop is displayed
The number of overlapping zones is displayed
When clicking on a specific location in the map, the hover panel gives additional information of the distance from the clicked location to the object which has a distance zone. If the "Count Hits instead of Distance" option is enabled, the overlay show the number of overlapping zones on the clicked location.
Adding and removing the Distance Zone Overlay
Template:Editor ribbon
How to add the Distance Zone overlay:
  2. Select 'Overlays' from the ribbon bar
  3. Select the Distance Zone overlay from the drop down menu
How to remove the Distance Zone overlay:
  3. Select the Distance Zone overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
Sometimes it can be convenient to duplicate an already existing overlay. To do so, follow the steps for removal, but select 'Duplicate' in stead of 'Remove'.
Modify the Distance Zone Overlay to count the number of overlapping zones
How to Select the Count Hits instead of Distance option:
  1. Select in the editor 'GEO DATA' from the ribbon
  3. Select the Distance Zone Overlay from the drop down menu on the bottom of the left panel
  4. Select the General tab in the right panel
  5. Check-mark the "Count Hits instead of Distance" option in the right panel
