Ground Price
Revision as of 14:02, 14 August 2018 by Rudolf@tygron.nl (talk | contribs)
Ground Price
The price is the assigned numerical and/ or monetary value in exchange for transfer of ownership or services provided.
The Ground price forms the essential basis of transactions in the Tygron Platform. It may be fixed or negotiated during the course of dealings between the stakeholders involved.
How the ground price is implemented in the Tygron Platform
Land transactions (and buying and selling of constructions) between stakeholders, to change ownership in the 3D world, are an integral part of the Tygron Platform. Therefore, ground prices are also implemented in the Tygron Platform. Not only has ground in the Tygron Platform a fixed price per surface unit, also lowering and raising the terrain height can be set to a fixed price. After the ground price for buying and selling land is set in the editor, users can even negotiate and adjust the ground price later on in the actual session.
Ground price types available
There are three types of ground related prices implemented in the Tygron Platform, in order to better visualize the costs involved in user's actions; the actual ground price per surface unit, the price it costs to raise terrain from water level to ground level, and the price to lower terrain from ground level to water level.
Ground price
The ground price is the purchase price of an area in an amount of money per surface unit. Depending on the regional selections made in the editor/ Wizard, the values can be very different between the regions. For example: the European region calculates the ground price in Euro per square meter, while the US region uses dollars per square foot.
Price to lower land from ground to water level
The price to lower land from ground to water level is important when actions adjust terrain height. For example, if an action creates open water to be able to improve the water storage of an area, the costs reflect the terrain adjustment.
Price to raise land from water to ground level
The price to raise land from ground level also plays its part in the Tygron Platform. When an action raises the ground level with one meter to resolve a flood danger, costs involved with adjusting the terrain height are calculated based on this price.
How to change the ground price
Template:Editor ribbon
Ground Price in the Bottom Panel.
To change the prices in the project, open the Ground Price panel in the Editor, from the 3D world menu. Changes in any of the three values are immediately implemented.
How to change ground prices:
  1. Open the Ground Price panel from 3D world.
  2. Change any of the available prices, as desired.
