Tygron Query Language
This article is a stub.
Queries
Clauses
The following groups of clauses exist:
Specific polygons
Clause As a polygon As an item Type
AREA The requested data must intersect with this area. It must be data of this area specifically. ID indicating a specific area.
NEIGHBORHOOD The requested data must intersect with this neighborhood. It must be data of this neighborhood specifically. ID indicating a specific neighborhood.
ZONE The requested data must intersect with this zone. It must be data of this zone specifically. ID indicating a specific zone.
TERRAIN The requested data must intersect with this terrain type. It must be data of this type of terrain. There are no specific "instances" of terrain. ID indicating a type of terrain.
Unspecific polygons
AREA_WITH_ATTRIBUTE The requested data must intersect with at least one area with this attribute. N/A Attribute name of one or more areas.
NEIGHBORHOOD_WITH_ATTRIBUTE The requested data must intersect with at least one neighborhood with this attribute. N/A Attribute name of one or more neighborhoods.
ZONE_WITH_ATTRIBUTE The requested data must intersect with at least one zone with this attribute. N/A Attribute name of one or more zones.
TERRAIN_WITH_ATTRIBUTE The requested data must intersect with terrain with this attribute. N/A Attribute name of one or more terrains.
Grids
MAXGRIDVALUE It must have at least this value on a grid overlay. N/A Decimal number.
MINGRIDVALUE It must have at most this value on a grid overlay. N/A Decimal number.
GRID It must fall within this grid. It must be data of this grid overlay specifically. ID indicating a specific zone.
GRIDTYPE It must fall within this type of grid. (If multiple grids of the same type exist this behavior is uncertain.) It must be data of this type of grid, not a specific "instance" of this grid. Technical name indicating a type of grid overlay.
Note that each grid automatically covers the entire map, unless a minimum gridvalue or maximum gridvalue is defined. For queries such as GRIDAVG, this can be acceptable. However, for example, a query of SELECT_LANDSIZE_WHERE_GRID_IS_2 is functionally the same as SELECT_LANDSIZE.
