Excel
What is an Excel file
An Excel file is a file, consisting of one or multiple tables of values, generally used in business environments for administration and calculation purposes. A single file can consist of multiple sheets. Each sheet is a grid of cells, each possibly containing either a value or a formula.
Excel files can be created and edited using a variety of programs. The most obvious program is by using Microsoft Office's Excel. Alternative programs include OpenOffice or LibreOffice, although minor differences in both use and calculation can occur, and support for these differences may be limited.
For the Tygron Engine, the file format .xlsx is specifically required.
How do Excel files relate to the Tygron Engine
One of the core functions of the Tygron Engine is to calculate prospective effects of actions and scenarios. Depending on the case being explored, what exactly to calculate and the precise method of calculation can vary. To provide the greatest freedom in the ability to configure a project with relevant, accurate, and third-party approved calculation models, the Tygron Engine allows some calculation to be made in Excel files. Most notably indicators can easily be created or adjusted by inspecting and editing the underlying Excel file. By defining specific cells to act as input and output for the calculation, the Tygron Engine can perform calculations using user-defined Excel files.
General structure of Excel files
Excel files, in general, have three parts to them: input, calculation, and output. The input and output are "connected" to the Tygron Engine. The contents of each input cell is changed by the Tygron Engine to reflect some form of data from the project. Each output cell is eventually read by the Tygron Engine, and its content used in some fashion. Input cells, and some of the output cells, are defined using TQL.
Cell types
Cells can be divided into 4 categories: Output, Input, Calculation, and Unused cells.
Output
The most important part the Excelfile is the output. At least one cell in the file is required to be an output cell, the content of which the Tygron Engine can use during a session. In each excel file, one of the cells must be named EXPLANATION. Excel Indicators and Zone Excels have a number of other output terms available for use. More output cells can be defined using TQL's UPDATE statements.
Input
Next to the output cells, the input cells are most important. You will generally want your Excel file to produce different outputs based on the current state of the project or session. Input cells are always defined using TQL.
Calculation
Lastly, there are the calculation cells. It's likely you don't want to output the data from the engine directly. Instead, you want to use it in some form of calculation, and display only the result, likely with some formatting. For example, you may not want to return the amount of green and the amount of houses, but the amount of green per house, rounded to a decimal or two, with some unit appended to it. Any cell, even empty cells, are deemed to be calculation cells if they are referenced by an output cell, because their contents are calculated (evaluated) to determine what the output will be.
Unused cells
Lastly there are unused cells. These are cells which are not input cells, and are not referenced directly or indirectly by output cells. Empty cells, when referenced directly or indirectly by output cells, are evaluated, and thus seen as used. Unused cells can contain values or even formulas, or even reference input cells. Unused cells with formulas can be useful when creating or inspecting excel sheets, to provide insight in how the calculation works.
Naming cells
The functioning of Excel files in the Tygron Engine hinges on the named cell functionality in Excel files. Input cells and Output cells require names to be set before they function as such. If the required output cells don't exist (for example, no cells are named EXPLANATION), the Excel file will not function as expected in the Tygron Engine. To set a cell name in an Excel file, select the cell and enter its name in the name field (just under the ribbon).
- Open the Excel file in Microsoft Office Excel
- Select the cell you wish to use as output cell
- In the top left of the window, find the "Name" field (just under the ribbon)
- Enter the name for the cell (for example:
EXPLANATION) - Press "Enter"
Correcting and removing cell names
There may be a number of reasons to correct the naming of a cell:
- The cell is no longer required
- The cell no longer exists
- The cell has been given multiple names
- The same name has been applied to multiple cells, or a range of cells
- The name of the cell is no longer correct, and needs to be changed
To correct issues like these, you can use the Name Manager in Microsoft Office Excel. You can find the Name Manager under the "Formulas" tab in the ribbon.
The Name manager displays a list of all assigned names in the Excel file, as well as what cells they refer to, and what the current value of those cells are.
To edit a cell name, or change what cells are referred to by that name, select it, and select "Edit". The "Edit Name" panel will appear, where you can enter a new name, as well as redefine to what cell the name refers.
To delete one or multiple names, select them in the Name Manager, and select "Delete". You will be asked to confirm that action.
Using Excel files in the Tygron Engine
Used in a number of places, but function the same everywhere
Uploading and Downloading
Either upload a new file, select an existing file, or update an existing file
Debugging
Download file using Debug Excelsheet, inspect values, make changes to original and upload adjusted original
Advanced Excel techniques
Filtering data, HTML, combining text, VARs, X queries, ID queries, _CURRENT and _MAQUETTE postfixes, colors in attributes, colors in HTML/CSS
Excel tips
Performance, colors in excel formatting, using sheets, possible issues
