Version 2023.1.1
Version Preview 2023.1.1 is released on preview.tygron.com on September 16th 2022.
Water
- To improve the Breach Growth a new inner water level measurement area can be defined.
- Water wizard splits Breaches into 3 separate steps for more control.
- Object (Breach, Culvert, etc) now also supports "datum" and "width" measurements when selecting it again.
- Measurements can be exported more easily and flow is stored in m3/s.
- Objects outside the limit area are no longer marked as "invalid".
Geo Wizard
- DXF import now also supports True Colors.
API
- The OBJECT_DATUM_OUTPUT attribute measuring the datum at both ends of e.g. a culvert is now split into two separate attributes (OBJECT_DATUM_OUTPUT_A, OBJECT_DATUM_OUTPUT_B).
Other
- Several improvements to textures.
- Several smaller bug fixes.
