How to import a DWG file in ArcGIS Pro
A DWG (Drawing) is used in CAD software and can be exported from most 3D animation packages.
How to import a DWG file into ArcGIS Pro:
- In ArcGIS Pro go to the "Map" tab and select "Add Data"
- Choose the DWG file. If the file is not visible in the add Data panel, click on the refresh button (top right corner)
- Select the Multipatch layer, right click on the Multipatches layer and choose properties.
- Select the Elevation tab and select On the ground and then Ok to place the model on the surface terrain.
- An AutoCAD 2004 or AutoCAD release 14 export works best to create an SLPK file
| <<Back to SLPK manual |
