Floor height m (Shadow Overlay)
| Icon | Attribute | Unit | Range | Description |
| FLOOR_HEIGHT_M | m | 0-100 | The height per floor for a surface geometry described by a Building, used to calculate foliage height. |
- The Foliage height is calculated as the FLOOR_HEIGHT_M multiplied with the (largest) amount of floors of a Building's sections.
- The Foliage height for a Building will be the same for each position inside the Building. The height is extrapolated using the Foliage crown factor. The Building polygon should therefore hold the Tree trunk and not its foliage.
- When multiple Buildings overlap for a particular grid cell, the Foliage height is averaged.
- The value must be in the range of 0 and 100 meter.
