Key (Sight Distance Overlay)
(Redirected from Distance zone m (Sight Distance Overlay))
KEY | m | -3.4028235E38 to 3.4028235E38 | Key used to retrieve the maximum distance from an Item a line-of-sight is allowed to extend. | DISTANCE_ZONE_M |
- If the distance is 0, the Item is excluded from line-of-sight calculations.
- Negative values are not allowed. If a negative distance value is used, it is considered 0.
- When using the Api session event editor overlay set key value endpoint, this attribute can be set for a Sight Distance Overlay using the default key KEY.
API Endpoints
