Api session items actionlogs
API Endpoint: /api/session/items/actionlogs/
Default Query:
https://engine.tygron.com/api/session/items/actionlogs/?token=API_TOKEN
Example Response:
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/actionlogs/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/actionlogs/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/actionlogs/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/actionlogs/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/actionlogs/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/actionlogs/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/actionlogs/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/actionlogs/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/actionlogs/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/actionlogs/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/actionlogs/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/actionlogs/?f=ZIPSMILE&token=API_TOKEN
Api Model ActionLog
API Model description of ActionLog
Name Type Description
action ParticipantEventType
budget double
buildingIDs int[]
id int
itemID int
mapLink MapLink Maplink
mp MultiPolygon MultiPolygon
point Point Point
scoreAfter Map<int,double>
scoreBefore Map<int,double>
simTime long
stakeholderID int Stakeholder ID
subject String
version int
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
