Api session event editor zoning set color
API Endpoint: api/session/event/editorzoning/set_color/
Description: Set the color of a Zone
| 0 | REQUIRED | (ZONE Integer ID or multiple integer values in array [1, 2, 3]) | Zones | |
| 1 | REQUIRED | (TColor or multiple values in array [a, b, c]) | Colors |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, -65536 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ -65536, -16744448, -16776961 ] ]'JavaScript example POST
body: '[ 1, -65536 ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/set_color/", options)
