Api session event editor zoning remove function category
API Endpoint: api/session/event/editorzoning/remove_function_category/
Description: Remove a permitted Function Category from a Category Zone
0 REQUIRED (ZONE Integer ID) Category Zone
1 REQUIRED (Enumeration) Function Category AGRICULTURE, BRIDGE, EDUCATION, GARDEN, HEALTHCARE, INDUSTRY, INTERSECTION, LEISURE, LUXE, NATURE, NORMAL, OFFICES, OTHER, PARK, PAVED_AREA, ROAD, SENIOR, SHOPPING, SOCIAL, STUDENT or UNDERGROUND
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorzoning/remove_function_category/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL" ]'
JavaScript example POST
 body: '[ 1, "SOCIAL" ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/remove_function_category/", options)
