Api session event editor upgradetype add
API Endpoint: api/session/event/editorupgradetype/add/
Description: Add a new Upgrade Type
200 Integer (Upgrade Type ID)
curl 'https://engine.tygron.com/api/session/event/editorupgradetype/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorupgradetype/add/", options)
