Api session event editor unitdataoverride remove color
API Endpoint: api/session/event/editorunitdataoverride/remove_color/
Description: Remove a color from the Unit Data Override's available unit colors
| 0 | REQUIRED | (UNIT_DATA_OVERRIDE Integer ID) | Unit Data Override | |
| 1 | REQUIRED | (Integer number) | Array Index of Color | |
| 2 | REQUIRED | (TColor) | Color |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/remove_color/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"argb" : -65536
'JavaScript example POST
body: '[ 1, 1, { "argb" : -65536} ]'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/remove_color/", options)
