Api session event editor unitdataoverride add
API Endpoint: api/session/event/editorunitdataoverride/add/
Description: Add a Unit Data Override for a Unit Data
0 REQUIRED (UNIT_DATA Integer ID) Unit Data
200 Integer (Unit Data Override ID)
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/add/", options)
