Api session event editor trigger set timeout
API Endpoint: api/session/event/editortrigger/set_timeout/
Description: Set the timeout of a Trigger
0 REQUIRED (TRIGGER Integer ID or multiple integer values in array [1, 2, 3]) Triggers
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Array of Timeouts in seconds
204 No Content
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_timeout/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_timeout/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editortrigger/set_timeout/", options)
