Api session event editor trigger add
API Endpoint: api/session/event/editortrigger/add/
Description: Add a new Trigger with a particular Timing
0 OPTIONAL (Timing or multiple values in array [a, b, c]) Timing
200 Integer[] (Trigger ID)
curl 'https://engine.tygron.com/api/session/event/editortrigger/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editortrigger/add/", options)
