Api session event editor source set uploader
API Endpoint: api/session/event/editorsource/set_uploader/
Description: Set the uploader name of a Source
0 REQUIRED (SOURCE Integer ID) Source
1 REQUIRED (String) Uploader Name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsource/set_uploader/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Uploader Name" ]'
JavaScript example POST
 body: '[ 1, "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/set_uploader/", options)
