Api session event editor source add service
API Endpoint: api/session/event/editorsource/add_service/
Description: Add a new Service Source, given a Geo Format, Name, URL and Uploader
0 REQUIRED (Enumeration) Geo Format BGT_GML, DXF, ESRI_IMAGE, ESRI_JSON, GEOJSON, GEOPACKAGE, GEOTIFF, I3S, OSM, WCS_TIFF, WFS_GML, WFS_JSON or WMS_IMAGE
1 REQUIRED (String) Name
2 REQUIRED (String) URL
3 REQUIRED (String) Uploader Name
200 Integer (Service Source ID)
curl 'https://engine.tygron.com/api/session/event/editorsource/add_service/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GEOJSON", "Name", "URL", "Uploader Name" ]'
JavaScript example POST
 body: '[ "GEOJSON", "Name", "URL", "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_service/", options)
