Api session event editor sound set volume
API Endpoint: api/session/event/editorsound/set_volume/
Description: Set the volume of a Sound
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (Floating point number) Volume
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 76 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 75 ]'
JavaScript example POST
 body: '[ 1, 76 ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_volume/", options)
