Api session event editor sound set filename
API Endpoint: api/session/event/editorsound/set_filename/
Description: Set Filename
| 0 | REQUIRED | (SOUND Integer ID) | Sounds | |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsound/set_filename/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_filename/", options)
