Api session event editor sound remove
API Endpoint: api/session/event/editorsound/remove/
Description: Remove existing Sound
0 REQUIRED (SOUND Integer ID or multiple integer values in array [1, 2, 3]) Sounds
curl 'https://engine.tygron.com/api/session/event/editorsound/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsound/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorsound/remove/", options)
