Api session event editor plot set owner
API Endpoint: api/session/event/editorplot/set_owner/
Description: Set the owner of a Plot
0 REQUIRED (PLOT Integer ID) Plot
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (owner)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorplot/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorplot/set_owner/", options)
