Api session event editor plot add
API Endpoint: api/session/event/editorplot/add/
Description: Add a new Plot with an owner
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (owner)
200 Integer (Plot ID)
curl 'https://engine.tygron.com/api/session/event/editorplot/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorplot/add/", options)
