Api session event editor overlay set entry value
API Endpoint: api/session/event/editoroverlay/set_entry_value/
Description: Set the value of an entry of an Overlay's legend
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Integer number) | Entry ID | |
| 2 | REQUIRED | (Floating point number) | Value |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 76 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 59 ]'JavaScript example POST
body: '[ 1, 1, 76 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/", options)
