Api session event editor overlay add difference entry
API Endpoint: api/session/event/editoroverlay/add_difference_entry/
Description: Add an entry to the difference legend an Overlay
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Names
2 OPTIONAL (TColor or multiple values in array [a, b, c]) Colors
3 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name 1", "Name 2", "Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/", options)
