Api session event editor neuralnetwork remove
API Endpoint: api/session/event/editorneuralnetwork/remove/
Description: Remove a Neural Network
| 0 | REQUIRED | (NEURAL_NETWORK Integer ID or multiple integer values in array [1, 2, 3]) | Neural Networks |
| 200 | Boolean (Byte array content) |
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/remove/", options)
