Api session event editor neuralnetwork add
API Endpoint: api/session/event/editorneuralnetwork/add/
Description: Add a new RCNN via a byte array of a Open Neural Network Exchange
0 REQUIRED (String) Name
1 REQUIRED (byte or multiple values in array [a, b, c]) Byte array content
2 REQUIRED (String) Uploader Name
200 Integer (Neural Network ID)
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", 1, "Uploader Name" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorneuralnetwork/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ 1, 2, 3 ], "Uploader Name" ]'
JavaScript example POST
 body: '[ "Name", 1, "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorneuralnetwork/add/", options)
