Api session event editor netsetting set cluster fraction connected
API Endpoint: api/session/event/editornetsetting/set_cluster_fraction_connected/
Description: Set the fraction with Net Loads of Net Clusters that are set to connected
0 REQUIRED (Floating point number) Fraction
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '81'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '16'
JavaScript example POST
 body: '81'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/", options)
