Api session event editor netcluster remove all clusters
API Endpoint: api/session/event/editornetcluster/remove_all_clusters/
Description: Remove all Net Clusters with Net Loads belonging only to a particular Net Type
0 REQUIRED (Enumeration) Net Type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove_all_clusters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ELECTRICITY"'
JavaScript example POST
 body: '"ELECTRICITY"'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/remove_all_clusters/", options)
