Api session event editor chatchannel set tools
API Endpoint: api/session/event/editorchatchannel/set_tools/
Description: Set Tools
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
1 REQUIRED (Tool or multiple values in array [a, b, c]) Tool[][]
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_tools/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ [ "GET_SUMMARY", "VALIDATE_QUERY" ], [ "GET_SUMMARY", "EXECUTE_ENDPOINT" ], [ "VALIDATE_QUERY", "GET_SUMMARY" ] ] ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_tools/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ "SEARCH_PAGE", "GET_PAGE" ], [ "SEARCH_PAGE", "EXECUTE_ENDPOINT" ], [ "GET_PAGE", "SEARCH_PAGE" ] ] ]'
JavaScript example POST
 body: '[ 1, [ [ "GET_SUMMARY", "VALIDATE_QUERY" ], [ "GET_SUMMARY", "EXECUTE_ENDPOINT" ], [ "VALIDATE_QUERY", "GET_SUMMARY" ] ] ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/set_tools/", options)
