Api session event editor chatchannel reset
API Endpoint: api/session/event/editorchatchannel/reset/
Description: Reset Chat Channel contents
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Channel ID |
| 200 | Boolean (Returns true if the channel was found and messages were removed, otherwise false.) |
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/reset/", options)
