Api session event editor chatchannel add message
API Endpoint: api/session/event/editorchatchannel/add_message/
Description: Add a new Chat Message with optional Image or PDF content
0 REQUIRED (CHAT_CHANNEL Integer ID) Channel ID
1 REQUIRED (String) Message
2 OPTIONAL (String) Content Mime Type (optional)
3 OPTIONAL (byte or multiple values in array [a, b, c]) Content bytes (optional)
200 Integer (Returns the ID of the resulting response message.)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/add_message/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Message" ]'
JavaScript example POST
 body: '[ 1, "Message" ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/add_message/", options)
