Api session event editor chatchannel add item channel
API Endpoint: api/session/event/editorchatchannel/add_item_channel/
Description: Add Chat Channel related to specfic Item
0 REQUIRED (MapLink or multiple values in array [a, b, c]) Item Maplink
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Item ID
200 Integer[] (ChatChannel IDs)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/add_item_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "SETTINGS", 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/add_item_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "SETTINGS", "ACTION_MENUS", "ADDRESSES" ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ "SETTINGS", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/add_item_channel/", options)
