Api session event editor chat set instructions
API Endpoint: api/session/event/editorchat/set_instructions/
Description: Set the instructions of a Chat Channel
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Chat Channels | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Instructions |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editorchat/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Instruction 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/set_instructions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Instruction 1", "Instruction 2", "Instruction 3" ] ]'JavaScript example POST
body: '[ 1, "Instruction 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/set_instructions/", options)
