Api session event editor chat add message
API Endpoint: api/session/event/editorchat/add_message/
Description: Add a new Chat Message with optional Image or PDF content
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID) | Chat Channel | |
| 1 | REQUIRED | (String) | Message | |
| 2 | OPTIONAL | (String) | Content Mime Type (optional) | |
| 3 | OPTIONAL | (byte or multiple values in array [a, b, c]) | Content bytes (optional) |
| 200 | Integer (Returns the ID of the resulting response message) |
curl 'https://engine.tygron.com/api/session/event/editorchat/add_message/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Message" ]'JavaScript example POST
body: '[ 1, "Message" ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/add_message/", options)
