Api session event editor actionmenu set name
API Endpoint: api/session/event/editoractionmenu/set_name/
Description: Set the name of an Action Menu
0 REQUIRED (ACTION_MENU Integer ID or multiple integer values in array [1, 2, 3]) Action Menus
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Names
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name 1", "Name 2", "Name 3" ] ]'
JavaScript example POST
 body: '[ 1, "Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/set_name/", options)
