Api session event editor actionmenu set active for stakeholder and scenario
API Endpoint: api/session/event/editoractionmenu/set_active_for_stakeholder_and_scenario/
Description: Make an Action Menu active for a Stakeholder in a particular Scenario
| 0 | REQUIRED | (ACTION_MENU Integer ID) | Action Menu | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 2 | REQUIRED | (SCENARIO Integer ID) | Scenario | |
| 3 | REQUIRED | (true, false) | Active | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/set_active_for_stakeholder_and_scenario/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, true ]'JavaScript example POST
body: '[ 1, 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/set_active_for_stakeholder_and_scenario/", options)
