Api session event answer upgrade ask date
API Endpoint: api/session/event/answer/upgrade_ask_date/
Description: Stakeholder planned the Upgrade date for a Building via a Popup
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (BUILDING Integer ID) Building
2 REQUIRED (POPUP Integer ID) Popup
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/upgrade_ask_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/upgrade_ask_date/", options)
