Api session event answer net producer connect
API Endpoint: api/session/event/answer/net_producer_connect/
Description: Connects a Net Cluster as a producer
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/net_producer_connect/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/answer/net_producer_connect/", options)
