Api session event answer net accept connect
API Endpoint: api/session/event/answer/net_accept_connect/
Description: Accepts the connection of a Net Cluster
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/net_accept_connect/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/answer/net_accept_connect/", options)
