Api session event answer measure ask construction date
API Endpoint: api/session/event/answer/measure_ask_construction_date/
Description: Stakeholder planned the construction date for a Measure via a Popup
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure | |
| 2 | REQUIRED | (POPUP Integer ID) | Popup |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/measure_ask_construction_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript example POST
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_ask_construction_date/", options)
