Api session event answer delete popup
API Endpoint: api/session/event/answer/delete_popup/
Description: Deletes a Popup; invalid ID are ignored
0 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Popups
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/delete_popup/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/answer/delete_popup/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/answer/delete_popup/", options)
