Api session event answer building construction approval
API Endpoint: api/session/event/answer/building_construction_approval/
Description: Stakeholder approves the construction of a Building
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (BUILDING Integer ID) Building
2 REQUIRED (true, false) Approves true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/building_construction_approval/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_construction_approval/", options)
