Api session
API Endpoint: api/session/
GET geotiff
API Endpoint: api/session/overlay.geotiff
Parameters:
Name Location Type Default value
format Path String
crs Query String EPSG:3857
id Query Integer -1
maptype Query Map Type MAQUETTE
difference Query boolean false
timeframe Query int 0
scale Query double 1
value Query HeightOperator
bbox Query String
Examples
Complete Grid Overlay (upper-left is 0,0 and lower-right is 250,250):
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&token=API_TOKEN
Query with local gridcell BBOX (upper-left is 0,125 and lower-right is 125,250):
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&bbox=0,125,125,250&token=API_TOKEN
Query with Scale: 50% (scale=0.5):
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&scale=0.5&token=API_TOKEN
Query for Timeframe: 0 (timeframe=0:
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&timeframe=0&token=API_TOKEN
Query for MapType: CURRENT (maptype=CURRENT):
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&maptype=CURRENT&token=API_TOKEN
Query for export CRS: EPSG:3857:
https://engine.tygron.com/api/session/overlay.geotiff?id=ID&crs=3857&token=API_TOKEN
GET asciidxdy
API Endpoint: api/session/overlay.asciidxdy
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&bbox=0,125,125,250&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&scale=0.5&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&timeframe=0&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&maptype=CURRENT&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciidxdy?id=ID&crs=3857&token=API_TOKEN
GET asciisquarem
API Endpoint: api/session/overlay.asciisquarem
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&bbox=0,125,125,250&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&scale=0.5&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&timeframe=0&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&maptype=CURRENT&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarem?id=ID&crs=3857&token=API_TOKEN
GET asciisquarecrs
API Endpoint: api/session/overlay.asciisquarecrs
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&bbox=0,125,125,250&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&scale=0.5&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&timeframe=0&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&maptype=CURRENT&token=API_TOKEN
https://engine.tygron.com/api/session/overlay.asciisquarecrs?id=ID&crs=3857&token=API_TOKEN
GET points
API Endpoint: api/session/overlay.points
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoJSON: Legend Points (center):
https://engine.tygron.com/api/session/overlay.points?id=ID&token=API_TOKEN
GET polygons
API Endpoint: api/session/overlay.polygons
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoJSON: Legend Polygons:
https://engine.tygron.com/api/session/overlay.polygons?id=ID&token=API_TOKEN
GET multipolygons
API Endpoint: api/session/overlay.multipolygons
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoJSON: Legend MultiPolygons:
https://engine.tygron.com/api/session/overlay.multipolygons?id=ID&token=API_TOKEN
GET gpkgpoints
API Endpoint: api/session/overlay.gpkgpoints
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoPackage: Legend Points (center):
https://engine.tygron.com/api/session/overlay.gpkgpoints?id=ID&token=API_TOKEN
GET gpkgpolygons
API Endpoint: api/session/overlay.gpkgpolygons
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoPackage: Legend Polygons:
https://engine.tygron.com/api/session/overlay.gpkgpolygons?id=ID&token=API_TOKEN
GET gpkgmultipolygons
API Endpoint: api/session/overlay.gpkgmultipolygons
Parameters:
format Path String
id Query Integer -1
bbox Query String
Examples
GeoPackage: Legend MultiPolygons:
https://engine.tygron.com/api/session/overlay.gpkgmultipolygons?id=ID&token=API_TOKEN
