Api event user set user passwd
API Endpoint: api/event/user/set_user_passwd/
Description: Change the password for a given user. Returns the user's login key for continued authentication, or null if you are unauthorized to change that user's password.
0 REQUIRED (String) Username
1 REQUIRED (String) Password
200 String (String)
curl 'https://engine.tygron.com/api/event/user/set_user_passwd/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Username", "Password" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Username", "Password" ]'
fetch("https://engine.tygron.com/api/event/user/set_user_passwd/", options)
