Api event user set user active
API Endpoint: api/event/user/set_user_active/
Description: Set whether a specified user account is active. Returns whether the user was successfully updated.
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (String) Username
2 REQUIRED (true, false) Whether account should be active true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/set_user_active/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "", "Username", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "", "Username", true ]'
fetch("https://engine.tygron.com/api/event/user/set_user_active/", options)
