Api event user set domain license
API Endpoint: api/event/user/set_domain_license/
Description: Change the License of a Domain to a different level.
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (Enumeration) License NONE, STARTER, T25_BRONZE, T25_DIAMOND, T25_EDU_FREE, T25_EDU_PRO, T25_GOLD, T25_PLATINUM, T25_SILVER or TRIAL
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/set_domain_license/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "", "NONE" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "", "NONE" ]'
fetch("https://engine.tygron.com/api/event/user/set_domain_license/", options)
